I have a MF 135 with the Perkins gas engine (AG3-152) that is leaking oil from the weep hole in the tachometer housing. I have just replaced both the seal in the adapter and the gasket between the housing and the cylinder head and yet it is still leaking oil. It's a fairly significant leak so it's not something I can manage by keeping the oil topped off. I've read through some of the previous posts on this topic and for the most part it appears that replacing the seal has solved the problem. I made sure to install the replacement seal facing the same direction as the old one so I don't think that is the issue.
Does anyone have any thoughts on what I should do next?
