Lighting issue on 135 continental
Chip67
New User
I re wired my wiring from the switch to the lights and installed new light switch today and my issues is one light is extremely dim and the other light is bright like it's suppose to be... any ideas to try? Lights are mounted on the fenders Massey ferguson 135 z145 continental
Sounds like a poor ground on the light that is dim. High resistance within the light assembly, light to fender, fender to chassis, could be anyone of those or multiple.
I ran separate green ground wires to my headlights, clamped the green wire around the light bulb socket, with a very small hose clamp. Voila, fixed!
I will try running separate ground wires tonight when I get I m home from work and let you know what happens. Thank you
