231S injection pump seals
Said2much
New User
I have a 231S tractor that has diesel coming out the weep hole on the underside of the injector pump but still runs great. I just need seals put in and our MF place closed so I am looking for someone who can put seals in it.
Don't know where you are located but there are usually injection pump shops in most areas that work on pumps and injectors, it doesn't need to be an MF shop.
You can always make contact with Dieseltech or one of the other pump guys that visit this site. You should be aware some won't do just a couple seals, its all or nothing, because they have been burnt when something else starts leaking and they are expected to warranty it.
(quoted from post at 15:12:47 02/17/20) Don't know where you are located but there are usually injection pump shops in most areas that work on pumps and injectors, it doesn't need to be an MF shop.
I have looked into that but everyone local wants to rebuild it for $1200 to $2000 and Dieseltech doesn't have an email listed. In another thread someone said $500 and Dieseltech said he could do it cheaper. Where is Dieseltech???? lol
Old laptop died, just got the new one. E-mail is [email protected] if you have questions. You have a Delphi model DP 200 pump, as model number starts with 89. I do have the shaft seals for that pump, and can replace them ONLY. Pumps starting with 85 I have all repair tools for, the 89 models I don't have all the tools for and will replace shaft seals ONLY on that series as the seals are flimsy in my opinion..
