massey ferguson 102 loader
My first thought is it is likely the packings in the loader lift cylinders are getting weak. You can swap the lift hoses and bucket hoses at the control vale if you want and see if the problem moves with the hoses. If the loader is still slow and the bucket is still fast it points to the lift cylinders or a hose failing internally. If the loader speed improves and the bucket slows, the problem in likely in the valve, maybe something blocking a port.
102 is just the loader, unless it is a Massey Harris not a Massey Ferguson. What tractor is it on and is it running from the tractor internal hydraulics or an engine driven front pump?
Found the problem control leveris worn so much that it is not opening the valve all the way I have bee trying to find lever but so far no luck
Likely salvage is all you will find, if any, and who knows if they will be any better than yours. Are those levers something like aluminum or an alloy? If steel or cast you should be able to have the holes built up and re drill them. Maybe put bushings in the holes or build new levers. Just some thoughts.
Donald,
The photos would be of the levers only. There were a couple different ones used. Photos might match to something else with a lever that might work.
