Company Logo Shop Now
TractorLinks.com
FEL For A 1975 MF 165 Diesel 2WD 58 Hp. Tractor
Michael2110
02-14-2020 13:01:55
This is my first tractor and all that I could afford at the time. I would like to install a FEL and there are a number of used units for sale, but how do I know what is compatible with my tractor. I have gone online and can't find anything helpful. I have found a couple of aftermarket suppliers for new units, but I cannot afford, nor justify $9K-$10K for an attachment to a $5k tractor. If I could figure out how to determine what works and what doesn't, it would make a product search so much easier.
tractorcedric
02-15-2020 12:07:49
 Re: FEL For A 1975 MF 165 Diesel 2WD 58 Hp. Tractor in reply to Michael2110, 02-14-2020 13:01:55
If you do find a loader, I have a two spool valve that would mount on the top of your trans. Then you would not have to have a front mount pump. There is a cover held down with two bolts. It has a supply tube with orings on it that delivers the pump oil to the three point. This valve would mount there instead.
chuckinnc
02-15-2020 10:36:01
I put a MF246 loader on my MF175, I think these fit many different MF tractors, still have the loader but sold the tractor & didnt take the quick attach mount that goes under the belly off. A 246 should fit your tractor, belly mounts for different sizes can be purchased separately.
FinnMD
02-14-2020 19:55:22
Many folks on this site know of good MF salvage yards and repair shops, if you provide your location may be able to give some resources. I know a few in MD and PA areas of US. Getting a local solution a money and time saver
AMcDowell
02-14-2020 16:00:51
165's are fantastic tractors. I believe a Massey 90 loader will fit as well as a Davis 101/102. A good way to find loaders that will fit is to look at classified ads online - look at the ads with loaders and see what loaders are on them. This isn't a fool proof way to know if a loader will fit but you know that someone got that loader to fit a 165. I would start with tractor house but any website that lists a bunch of 165's would work. Depending on what's in your area you may get lucky and find a plug and play or have to do some fab work and figure out the hydraulics. Most folks run a front mounted pump that runs off the crankshaft.
Good luck.
c.oawright
02-14-2020 14:48:03
Look for a Massey model 236 loader. Make sure the mounting brackets are with it. It bolts right on. Sometimes you can find a good used one. If it is an older model it will have a bucket that uses pins to attach it which is a pain. You can get a quick tac from palletforks.com and upgrade the loader to accept any skid steer attachment. The Titan adapter works great and is quality made. Just cut the ears off the bucket and weld them to the quick tach adapter. Then weld the plate to the bucket.
Jim.ME
02-14-2020 13:36:38
Unless you get lucky and find one with all the mounts and hardware off another 165 you will have to do some measuring and checking for each you find. If you find the brand and model of one that looks like it might fit sometimes you can search the web and see if the manufacturer made mounts for that loader to go on your tractor. Then given the vintage of your tractor and the loader the mounts likely will not be available from the manufacturer, or the manufacturer is no longer around, so you will have to build your own mounts. Installing used loaders on old tractors is common but it usually involves time, fabrication, and money. Not trying to be pessimistic and discourage you, just trying to give you a real idea of what you are up against.
It may help if you give an idea of where you are located such as area of a state, etc. and how far you are willing to go to get one. Someone might know of one near you, or a place to check.
Happy hunting, hope you get lucky.
504
02-14-2020 19:38:52
 Re: FEL For A 1975 MF 165 Diesel 2WD 58 Hp. Tractor in reply to Jim.ME, 02-14-2020 13:36:38
Check your local Trader papers.There are two around here that deal with N Fords and utility MF,and one good salvage yard. All of them get loaders often. Stop at a dealer and ask where you might find used parts.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
