Massey Harris 22 hydraulic
So my three point won't raise or lower. It just moves a little bit and then makes a squeal or buzzing sound. Like it is going over a relief valve or something. The cylinder is old enough that it does not have the adjustable poppet to use a remote cylinder. The cylinder has markings for plugs that can be removed to use a remote cylinder. Thanks for any help!
(quoted from post at 20:01:12 02/10/20) So my three point won't raise or lower. It just moves a little bit and then makes a squeal or buzzing sound. Like it is going over a relief valve or something. The cylinder is old enough that it does not have the adjustable poppet to use a remote cylinder. The cylinder has markings for plugs that can be removed to use a remote cylinder. Thanks for any help!
Checked your hydraulic fluid level on th front rservoir.
Sounds Like Pump trouble
