Mf 230 exhaust help
Denton Run
New User
Having a hard time finding a exhaust manifold for my tractor. My 230 has a continental gas engine with exhaust that exiits through the hood. Every manifold i have found looks nothing like the one on my tractor. This is what mine looks like. Any help anyone?
Using the MF part number it only seems to pull up the old combination manifolds. Have you contacted your Massey Ferguson dealer to see if they can help you?
(quoted from post at 10:35:36 02/07/20)
yep. No help there
If you are looking at pictures of manifolds on the internet they may not be using the exact picture of the manifold you need. Try tractorhousedotcom and do a part search for part number 1046679M1, you may email them a picture of the manifold after you contact them. Your only other alternative is used from tractor salvage yards.
(quoted from post at 14:58:28 02/07/20) If you are looking at pictures of manifolds on the internet they may not be using the exact picture of the manifold you need. Try tractorhousedotcom and do a part search for part number 1046679M1, you may email them a picture of the manifold after you contact them. Your only other alternative is used from tractor salvage yards.
i spoke with a few different vendors and that part number is only associated with the manifolds that exhaust below the tractor. I had this same issue when buying a new gas tank gor this tractor last year. Ended up having to modify the new tank.
