David Fisher
Okay, I plan to tackle this job myself in a few weeks at my workplace where we have lifts and all the tools needed. I have a few more questions for you that have been inside this area. Both the trans and the rear area share the same fluid. When I split this case apart to get at the Hydro pump will I need a new gasket or seals ? Once I have to top ( seat area ) off can I see everything inside toward the front as I join the two half's back together ? This pump needs to come out of the front once the tractor's separated instead of the top because it has the auxiliary pump. Will the PTO still need pulled out toward the rear ?
Thanks so much for your help.
