I own a 1966 Massey Ferguson 203 Industrial with the Perkins diesel engine. I bought a shop manual, but lo and behold, no instructions for removal or installation of the radiator. I added several pictures I have of the radiator area and tractor. I don't know if I should try to remove the radiator by removing the fuel tank and pulling it from above, or by removing the grill and hydraulic pump and removing it out the front. The shroud is attached to the sides of the radiator, so I could remove the side sheet metal body skirts that hide the side of the radiator on each side. Then I could detach the shroud, but will the radiator come up and out? Or out the front? Has anyone installed a new radiator in a MF 203 or similar tractor?
