Hi all,
I have a MF 135 4 Cyl petrol which seems to work OK
I am abit new to the operation of the tractor and recently made a single tine pipe layer which seems to be OK for what i want to use it for.
Problem is when I drop the uit down into a hole I have dug to start off the unit starts off ripping but pretty much straight away starts lifting back up onto the ground surface, within 1.5 meters.
My question is does the 3 point linkage use pressure to hold the ripper down at the level I want or is it based on weight.
The angle of the cutting tooth looks fine compared to professional units.
Are my hydraulics faulty or I just don't know what I am doing.
I was thinking of putting a Steel bar between the top linkage point and the rear ROP bar to keep the level down.
Don't want to buy one as i will only use once to do 100 meters of pipe.
Any input would be great.
cheers Jamie
cheers Jamie
