Company Logo Shop Now
TractorLinks.com
Re: Pulling my hair out over starter issues
2tractors
01-15-2020 04:43:39
Make sure paint is not present behind starter mount.
zack500
01-15-2020 09:10:10
 Re: Pulling my hair out over starter issues in reply to 2tractors, 01-15-2020 04:43:39
Ok, I got the tractor cranking. I was able to get 0 gauge cables with eyelet crimped on the end at NAPA. I sanded battery posts, sanded the area around where the ground is bolted to tractor, and the tractor fired right up. So it was one of the cables that was bad, or perhaps ground was losing contact. The funny thing is, the old cables look fine! I am not able to see any corrosion around any of the contacts. Maybe the wire was corroding on the inside. Thanks for all the comments and good advice from you guys! I really appreciate it!
rustred
01-16-2020 07:49:46
 Re: Pulling my hair out over starter issues in reply to zack500, 01-15-2020 09:10:10
I pretty much was going to guarantee you need cables. take those old ones and cut the ends off near the battery cables ends, pretty sure you will see green corrosion. I have found this many times.
old
01-15-2020 09:49:39
Battery cable go bad just from being old and used a lot. One or both ends could be corroded inside where you cannot see. Or the cable it self could have gone bad which does happen. The common man does not have a VOM that will test for resistance which can build up over the years and that is why they go bad
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
