Company Logo Shop Now
TractorLinks.com
Re: Pulling my hair out over starter issues
rustred
01-14-2020 08:51:53
you can buy a cheapo battery load tester for around 50.00 one of the best things you will spend money on. if you changed the battery and starter you would have seen if the cables are corroded. booster cables are pretty useless on a diesel engine. need the heavy guage ones and let booster unit run at about 2000 rpm for max amps. did you run the starter in a vise to make sure it kicks in spins over fast at least. all you have left is the cables to deal with. , if battery and starter is good. that green corrosion will work its way inside from the clamp down the wire. saw lots like this. that" wamp wamp" is that the engine trying to turn over??? if so it tell the story.
zack500
01-14-2020 09:44:42
 Re: Pulling my hair out over starter issues in reply to rustred, 01-14-2020 08:51:53
Yes, I did test the starter before I put it on. It engages and spins. You would think you could see green corrosion but I can't. But obviously there must be corrosion inside that is not evident. And yes, wamp wamp is the sound it makes trying to turn over.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
