autocarmark
New User
Per my prior questions and your helpful responses I now have the tractor split with clutch and flywheel removed. Upon inspection I have a few additional questions on how to proceed. I have attached a doc/photo below with three reference arrows. Also of note, I do have some transmission leakage into the clutch housing area that I d like to take care of. I m not sure if it is leaking from top shaft or end plate over bottom shaft. The other debris you see in the photo is dirt and remnants of the PTO clutch plate (i.e. not anything metallic).
1. When I replace the release/throw-out bearing, is this just one bearing or is it a combination of bearings/bushings ?
2. It looks like the PTO/driveshaft seals can be replaced from the front and involve multiple oil seals, bushings, and bearings. I would presumably replace all of these if I can access them from the front, right?
3. I assume this lower shaft cover plate can easily be removed and a gasket replaced. Is there any other seal that should be replaced here?
Regarding the recommendation to replace the pilot bearing, I assume that is the bearing inside the fly wheel, right?
Per the recommendation to get a genuine MF rear main seal, if I purchase from YT is that a genuine MF seal?
Are there any special tools I need to complete these recommendations or does all disassemble and assemble with a reasonable collection of mechanics tools? My manual references a special seal tool MFN-850, do I need it?
All insights and suggestions are appreciated.
Thanks again for your help!
