MF34 Front Loader Filter
Jaypat88
I am wanting to inspect the hydraulic oil filter on my MF34 front loader. I am curious how much hydraulic fluid should I expect to lose if I inspect the filter iif the fluid current level is full?
I would think the capacity of the reservoir would be in the operator's manual. I don't know the gallon amount; but that filter is ported right into the side frame reservoir so you will loose all the oil above the filter from the entire reservoir. I would start with a half dozen clean 5 gallon buckets (or a size that will fit under the drain if those won't) at hand, find the drain plug, and drain the reservoir, before opening the filter housing.
