Farmer Rock
hey guys,I posted a couple months ago about taking the mark 4 backhoe off my mf203,but it looks like I could only remove it semi permanently,so I guess that's my only option,i was wondering if all I have to do is loop the hoses before the backhoe,here is the way its set up,1st hose (3/4") from pump to backhoe,2nd hose (1")from pump to opposite side of reservoir's filter (mf200 loader),3rd hose (1") from rear of of loader frame to backhoe,4th hose (3/4") from bottom of loader valve to backhoe.....so my question is can I connect the two 3/4" hoses from pump to bottom of loader valve,and then plug 3rd hose (1") at the rear of loader frame?from what I can see,it is using the backhoe as a valve of sorts,since it runs to backhoe first then loader,but I will maybe down the road put quick couplers on it,but seeing as the backhoe will eventually need a lot of work,i will wait for that,and I won"t be using it that much anyhow,thanks,Rock
