Massey Ferguson 98 Oil Leak
dchj265
New User
I have a MF 98 with an oil leak that seems to be coming from between the engine and the transmission. Anyone else experience this? Thinking it is the rear main seal.
Usually only two choices in that area. Rear main seal or transmission input seal. If it is coming down at the back of the engine/ front of the clutch housing likely the rear main. Coming from a weep hole further back in the clutch housing it could be either. Engine oil is often darker/black and trans oil will usually be lighter brown/amber. Make sure oil is not running down from above the clutch housing, like a rocker cover leak or oil line, not as likely but I have seen such.
