Bio Diesel; Is any Amount Good?
21hunter
I was wondering about the use of bio Diesel and if there are any benefits to mixing small amounts of it with regular Diesel fuel in order to increase lubricity to fuel fuel system components? I?ve seen Dieseltech comment on other posts that biodiesel will gum up an injection pump and cause problems. Just wondering about limited amounts, or should I just stick to adding treatments such Howe?s or Power Service etc?
Thanks
Around here in central Texas all the pumps you get diesel from has a decal on them that says the diesel may contain up to 5% Bio-Diesel. Which would probably explain the rapid increase of injector pump leaking problems I've been seeing since bio-diesel was added.
