Re: MF32 Loader control valve
Wldwayne
New User
I have been trying unsuccessfully to get the parts to rebuild my loader control valve. I am not even finding rebuilds. Does anyone know of a aftermarket replacement? The return to tank is built in as part of the valve mounting plate. My control valve part number is 708582M91. I am also chasing a filter replacement kit for the loader as well the filter part number is 039161M91. Can anyone help me please? Thank you for your assistance.
Have you tried talking to Steve at Eberhard equipment in Santa Ana,CA and also Dorning Tractor in Ontario,CA they have a container where they keep their used valves and a variety of of other parts.
Also the hydraulic filter is available from NAPA WIX part# 51567
It looks like Jesse has you covered on the filter with the cross to Wix (51567) or NAPA (1567).
You say you can't find sealing parts for your valve so I am taking that to mean you have checked on kit #836520M91 at a MF or AGCO dealer. If you tear it all down, a hydraulic repair shop may be able to match all the parts.
If you have to go to an aftermarket valve you are right not to plan on finding one that discharges return oil through its mounting pad on the loader frame/reservoir. You could make, or have made, a plate matching the mounting bolt pattern with a pipe coupling (3/4" or 1") welded to it in line with the return hole in the reservoir. You could then have another plate welded to that plate to make a shelf to support a new aftermarket open center valve of your choosing, two lever or joystick. Leave room to hook up a return hose between the valve and the coupling. The return from the valve would be connected to the coupling in the plate using a hose and appropriate fittings.
