MF 200 loader help
jesse CA
Hello All
Might anyone have pictures of how the hydraulic suction and pressure hoses are routed on a MF 202 I'm trying to get as close as possible to how they may been routed originally
Hi Im working on replacing these hoses
have some photos of my tractor
Maybe these can help
As PTFarmer recently reminded me. There is a better online source than the manual I have. Search for Davis 102 Loader parts and you will see it show up. If you can't find it, send me an email.
Don
Thank you to all for your replies. I forgot to mention that I have a four bar linkage model 200 loader attachment which I'm in the process of trying to get mounted on my Massey ferguson 202 and I'de like to make the installation as neat as I possibly can as close to how the It may have looked originally when it left the factory. I've looked at the parts manual illustration for the parts required to install the suction and pressure lines. I having a problem trying to post the parts illustration from the AGCO parts book web site
Untitled URL Link
Still hoping someone might have a 200
loader mounted on a 202 who might be able
to take a picture of how the hydraulic
suction line and the hydraulic pressure
line are arranged where I think they are
routed along the right side of the engine
block or between the engine block and the
loader frame rail
This is the pipe on my MF 200 ? its a four bar loader so 200 is the model but model tag is long gone, Hydraulic suction line is on bottom tapped into Hydraulic reservoir pressure line runs above it in metal pipes along loader frame Hope this can help.
Jesse,
Did you get your answer for the hydraulic hose routing? If not, I have a 202 Work Bull with the MF 200 loader that I can take pictures of for you if you still need them.
Does your 202 have the backhoe attachment? No problem if not, just the power beyond connection for the backhoe will be a plug.
I will tell you this, the suction line on mine attaches to a 90 degree nipple in the loader frame (where you add the oil) just above the filter ( which is on the outside of the frame). The pressure line attaches to the bottom left (as you're sitting on the tractor) of the loader control valve. The power beyond hose (for the backhoe, if you have one) attaches to the bottom right side.
My suction and pressure lines are flexible, no way for steel lines due to the cast iron nose on the 202 Work Bull.
Let me know if you need pictures.
Roger
