mf65 up north
New User
We had some big windstorms in our area and lots of trees went down. I was cutting them free and dragging them in to a pile. I hooked on to one and thought it had broken off and was free. I hooked up and gave it a pull and it started to move but I believe branches dug in and I came to a halt. I lifted the 3pt a small amount and gave it another shot and it started to move. I realized I was popping a wheelie and pushed the clutch in to get back to ground. I shut down got the chain saw out and cut the tree into sections. I hooked the chain back up to drag the first section away and when I tried to lift the piece to stop it from digging in no lift.
Due to the fact we are in the process of building a new home on another piece of property I?ve had no time to get into repair mode. When this first happen I went through basic manual check list;
- pto still runs so no broken shaft
- went through double checking the quad
Basically it?s time to start pulling covers off and see what my dumb butt did to this old girl. My thinking is I popped the valve and I?m wondering if I should pick- up a new valve before I jump in?
Any thoughts on what may have happen would be appreciated.
