Bought MF165 with Perkins gas engine for $300 . seller said it had a rod knock. I thought good winter project Rebuild the engine . No
oil pressure. Pulled pump. stripped splines on shaft driving pump . Ordered new shaft . replacement shaft did not fit , Ordered new
gear to fit replacement shaft Reassembled oil pump, got oil pressure, also got oil leaks. Several of the 5/16" pan bolt treads have
been stripped so cannot tighten rear of pan enough to stop leaks . I'm thinking pull pan and retread stripped holes to 3/8". Any
comments . Ya , I know , Forget the winter projects!
