2tractors
Finally got the 135 diesel head retorqued and found about 3/4's turn difference and was surprised it was that much. Had to remove injectors now need to replace the new washers again I suppose, What do ya'll think?
While it's best to replace them, I have used them again long as sealing surfaces are clean. Make sure the hold down hardware are evenly torqued too, if not the injector tip could stick open, causing a LOUD engine knock..
