MF 1105 pto will not disengage
How bad is that to fix? Also my front end loader seemed to be very slow today? Would almost stop moving then start back.
The rear top link draft plates need removed, then the rear PTO drive gear box comes off. The floor in front of seat needs removed, then all the oil lines and charge pump plate needs removed. The PTO has a short shaft to remove before the clutch pack can be lifted out the top. Hope you have a service manual..
any idea on the loader being slow and not going all the way to the top, then after running 45 minutes it starts traveling all the way up but no down pressure.
