mf35 draft lever setting
chuckinnc
My 1962 mf35 has two lift levers, the larger inside one is for raise or lower, I got that. But the smaller outer
lever is for draft and position, all the markings are rubbed off or painted over, I only use position control
never draft, should this lever be up or down or in the middle?
Here is some additional information.
The 35 and 135 don't use the same internal linkage. There's a roller inside that needs removed FIRST on the 100 series before removing the lift cover that does not apply to the 35, 50, and 65 models..
