Brian-Ohio
I have a Ferguson TO30 6 volt that I recently acquired. I have replaced the points, condenser, distributor cap,, key switch, Coil, battery and some of the wiring. I checked the gapping on the spark plugs and the points. I have 6 volts at the battery, key, coil, distributor. When I try to start the tractor it turns over slow and I don?t have spark when I remove one of the spark plugs and hold close to a ground source. I checked the grounding on the positive side of the battery and made sure that it si metal on metal connection. I replaced the ground wire also and used battery terminal grease.
I have read various posts but what am I missing? I don?t know why it is turning over so slow and why I have zero spark.
