fishingbucks
New User
I have installed the AllState Ag power steering kit for my 135 and I can?t get the either the pump or ram to work. Everything looks correct but no power steering. I put on the hoses the only way I think you can as fittings only work on certain port. This is the kit from Turkey with useless instructions. When I turn wheel lock to lock I get fluid squirting out the top of pump through a check valve I guess. I can?t get the fluid churning in the pump creating bubbles like you would think it would do either. I don?t know which line is pressure or return on pump (top or bottom). It?s labeled on ram cylinder. What?s wrong?
