MF 65 vibration
Phil Tibbetts
I've heard about the MF 65 with the Perkins diesel having engine vibration because there is no crank balancer on it. Mine is good until I get above 1600 RPM, then you can feel the vibration in the steering wheel. Is this normal? First tractor I've ever had that I could feel vibration in. It starts and runs perfect otherwise.
The A4.203 and AD4.203 Perkins did not use the counter rotating balancer like the larger Perkins four cylinder engines did, which ran MUCH smoother. What you have is normal.
