jleonardwv
Bought this MF135 in May and used it a few times with a box blade. I knew it had some leaks when I bought it. I'm investigating the leaks now.
Leak #1. Someone drilled a hole in the bottom of the transmission housing? See photo. As I wiped the grime off the bottom of the transmission housing, I see a hole that seems to barely leak, maybe a drop every five minutes. So I curled up a piece of paper towel and stuck it in the hole to absorb. My thought was that perhaps it was formed as part of the housing and the moisture just got trapped in there over time, but when I stuck the paper towel piece up in there, it started gushing and clearly the hole goes all the way through!
Is that normal?
The fix I can think of is to put threads in the hole and plug it with a bolt. The photo shows fluid like motor oil dripping out, but the fluid seems to be a mix of transmission fluid and motor oil.
Is that normal?
