Massey Ferg55
New User
I have a TO30 that was converted to 12 volts and all the wiring from all the components was missing, so I have no idea what the correct connection sequence is what as there are many diagrams on the web. Is there anyone that can explain the proper connection flow with the components of the tractor listed below? Thank you very much and looking forward to getting this 1955 TO30 back to life.
12V Battery (550 CCA)
12V Solenoid (3 Posts)
12V Starter
12V Alternator (Single Wire)
12V Coil
Distributor
Starter Switch
Ignition Switch (4 poles with the middle pole stating Start
and the surrounding posts list IGN, BAT, ACC.)
Oil Pressure Gauge
Amp Gauge
12V Starter
12V Coil
Distributor
Starter Switch
Oil Pressure Gauge
Amp Gauge
