Company Logo Shop Now
massey 150 gas
shinnyboots
09-12-2019 08:25:34
ok gentlemen need to pick some brains I've got a Massey 150 gas engine I'm wanting to change the harmonic balancer out so I can install a front pump has anyone done this without disassembling the tractor's front end? I've got the bolt out which was a pain but do I need a puller to remove the harmonic balancer?
shinnyboots
10-20-2019 07:13:05
 Re: massey 150 gas in reply to shinnyboots, 09-12-2019 08:25:34
ok gentlemen I've got my front pump installed and plumed in everything is hooked up( after several color metaphors) haven't installed the fluid yet hoping and praying for no leaks. I think I'm going to have a problem the steering elephant nose on the power steering is going to hit my shaft that runs the pump when I turn to the left. this power steering came off a 165 Massey any body have ideas on how I can adjust the steering to prevent this any help will be helpful. I cant move the elephant nose because its has a flat spot for alignment( all ready took it off and tried)
ptfarmer
10-04-2019 21:31:15
I would use no less than a 14 gpm pump, you could run one with less gpm, but the loader won't work as fast.
shinnyboots65
10-06-2019 10:54:23
 Re: massey 150 gas in reply to ptfarmer, 10-04-2019 21:31:15
Ok thanks
shinnyboots
10-06-2019 18:00:12
 Re: massey 150 gas in reply to shinnyboots65, 10-06-2019 10:54:23
I will let yall know how it goes thanks again for the info
shinnyboots
10-03-2019 08:41:20
ok gentleman I replaced the balancer on this tractor without having to remove the front end it was a pain but after several colorful metaphors and making a puller I got it changed and the new seal installed my question is now what size pump would be best to run this loader I've checked on all the sights and read the info and am now more confused than ever I assume(and we all know what that means)that I need at least a 15 gpm pump to maintain a 10gpm flow am I correct in this or does it need to be bigger any help will be helpful
ptfarmer
09-12-2019 21:08:35
You got lucky, some had them, some didn't.
Don-Wi
09-12-2019 09:49:17
Are you sure you need to remove it? The adapter we had on our 165 bolted into existing holes on the original one.
Donovan from Wisconsin
shinnyboots65
09-12-2019 11:41:03
 Re: massey 150 gas in reply to Don-Wi, 09-12-2019 09:49:17
There are no mounting holes in the existing balancer to mount the adapter
ptfarmer
09-12-2019 09:05:30
You do need a puller to remove the pulley, not going to happen with the front axle support still on the tractor.
shinnyboots65
09-12-2019 11:42:01
 Re: massey 150 gas in reply to ptfarmer, 09-12-2019 09:05:30
I was afraid u were going to tell me that
Copyright © 1997-2020 Yesterday's Tractor Co.
