WANTED: MF 290 Brake Reservoir
LJS30
Hey guys I am hoping someone would have this thing in their possession. Please let me know asap if you have this part and are willing to sell.
[/img]
I think what you have is a 7/8x14 ORB fitting which is a straight fitting that seals with the o-ring instead of a tapered pipe thread. A
fitting should be readily available at any hydraulic shop. you can also buy an adapter to go from 7/8 ORB TO 1/2 NPT ON FLEA BAY.
Reservoir still available from Massey...bit pricey though. Part number 418646m1 (Check to see if that is the part number for your tractor)
Wayne
Yea I was quoted $121.00 bucks for this little reservoir. I was hoping someone had a second hand one in good shape or some repro brand that would work just as well. This is a strictly work machine and not a restoration project. I just cannot, yet, justify spending that much for a reservoir.
Hi, if you can't get anything your side
of the pond you could try Ron Greet in
Devon UK or Tractor Breakers in Northern
Ireland.
DavidP, South Wales
Thanks David!! I shot Tractor Breakers a message so we'll see what they say. I just can't justify paying that much money for a small plastic reservoir.
A few cars use reservoirs like that, if that one uses a hose on the bottom you maybe able to find one off a car that will work (I would look on e bay)
