Company Logo Shop Now
TractorLinks.com
davis 102 hydraulic pump
wildwilf
09-10-2019 16:37:58
Hello
Does anyone know where I can get the pump body part # 400297m1 is the Massey # or a pump for this loader
Or if the one they sell here will work Part No: 40P018LAJSA
Thanks
Wilf
wildwilf
09-27-2019 10:50:30
 Re: davis 102 hydraulic pump in reply to wildwilf, 09-10-2019 16:37:58
Well the L827-10X-LB hydraulic pump works great on my 63 MF 202 ind.
A couple things that will need to change
the mounting bolts to 7/16 x 1 1/4, also had to change the plumbing configuration on the filter.
It might run a bit slower but nothing that is really noticeable.
I hope this helps other people, I know I had a real B@#$% of a time finding one that would work.
wildwilf
09-13-2019 19:19:10
I'm just hoping that it works right I will post the results after I get it on.
ptfarmer
09-13-2019 08:46:36
14 gpm is the minimum I'd use on a FEL.
wildwilf
09-13-2019 06:05:45
It runs 14gpm in stead of 17
ptfarmer
09-12-2019 22:20:32
How much less gallons per minute, less gpm the slower the loader will work.
wildwilf
09-12-2019 18:23:28
I have figured out the L827-10X-LB pump mounts the same and has the same shaft it is just less gallons per minute.
So I going to try it
Thanks
Wilf
ptfarmer
09-12-2019 09:06:39
X2 ^^^^^^^^^^^^^^^^^^
shinnyboots
09-12-2019 08:33:30
u might check surpluscenter.com they have gear pumps
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
