Z134 Timing
My shop manual shows a timing for my Z134 at around 28 deg. at 2200 RPM. I cannot get anywhere near 2200 RPM out of my tractor. Does anyone have a lower RPM degree scale?
thanks
My tractor is a 1959 or so MF35
Just do a search for 35 ferg or to35 ferg or 50 ferg timing. There are several. Remember: if the advance in bottom of dist. is weak or worn. You won't be able to use the suggested lowers settings.
I think last time I timed my to 35 was at 800 rpm an 11-13 degrees BTC
