Massey Ferguson 655 swather
Wheeta
New User
Pretty sure I've lost the right hand drive motor in this old swather, (we just do circles now). Its a couple hundred yards to the shop. Does anyone know; can I tow this with out hurting the other final drive or is there a lockout on the drive like the newer swathers have, I didn't see anything obvious. An Operators manual will probably tell me but I don't have one yet, Thanks for the help.
Tom Wheeler
Don?t tow it unless you remove the drive chain check the side that
isn?t driving to see if the drive chain jumped off and also check to see
if the spline coupler that drives the pump on that side is still good we
have a 775 it?s pretty much the same as the 655
chain the rear wheel to the front of a tractor and use the tractor to do the steering and drive the swather just like normal take two guys with the tractor in the rear it will keep the swather straight you both got to work togeather moved many that way
