have mf 1100 diesel perkins 3.54 cav injection pump. new lift pump with sediment bowl. new fuel shut off cable. has not been run in a few years. stored inside. drained water from primary filter base. bleed 2 fuel filters & closed aok. good fuel flow no air. bled injection pump both screws aok. good fuel flow no air. op manuals says to crack hi pressure lines on injector base & crank over. no fuel seen. tightened back up & bled top of injectors aok. good flow & no air. why is there no fuel on pressure line into injector ? fuel shut off in OFF position when pulled toward seat ? thanks
ran aok when last shutoff. replaced rear main seal & clutch discs
