TO-35 governor issue
I am diagnosing an issue with this TO-35.
The throttle wants to creep up on its own.
Also the govenor does not seem to be operating like it used to.
HAs anyone had experience in the govenor on this unit?
Is there a typical part or parts to correct this?
Also, how can I verify it is the govenor? And not something else?
Thanks
How is the governor operation different? The governor is attached to the front of the camshaft and is access by removing the front engine cover. Before doing that, make sure all the external linkages are in adjustment and springs and friction washers are present and in good shape - attached is the definitive adjustment procedure
Throttle and governor linkage adjustment
I replied to you in 'classic view' and the post doesn't show in 'modern view' - make sure the throttle linkage is adjusted and all the springs and friction washers are present - here's the definitive article on adjusting the external elements - http://fergusontractors.org/nfs/wp-content/uploads/technical-articles/Throttle-Linkage-Adjustment.pdf
The governor is attached to the front end of the camshaft and is access by removing the front engine cover -
