MF40 Industrial-looking for Tube Assembly fuel pump
Greene Acres
New User
I'm trying to find a part number 513780M91 Tube Assembly, Fuel Pump for a MF40 Industrial Tractor. I checked with my AGCO dealer and he said it is listed as discontinued. Does anyone know where I might find one of these or have a suggestion of an option? Thanks, Earle
If your ends and black sealing washers (olives? grommets?) are ok, I've cut the line midway and spliced on a short piece of fuel line hose. I've done that on several, to make it easier to line them up on reassembly.
I've also resorted to making up the grommets - clamping a 1/4" long piece of correct size fuel line on a correct size bolt with head and nut ground down below the od of the olive, chucking in a drill and grinding the outside off the grommet down to the desired diameter.
Jack, Thanks for the tip on splicing in fuel line hose. That could be a solution for me. I do have new olives so that's one thing I don't have to do. Thanks again for you information and time. Earle
