MF-65 Gas Starter Switch - advice needed
spayne67
I am rewiring my 1958 MF-65 and got to the starter switch. There are three letters associated with the terminal I, L and possible B (hard to read). I want to make absolutely sure I wire it correctly. Unfortunately I failed to pay close attention to where the wires were before I unhooked them. The lights are associated with the starter switch. Thanks in advance.
Likely assumption could be B battery, I ignition, L lights. Use an ohm meter to confirm what position activates which terminals.
Just be sure to run it thru the neutral safety switch. I bought an old MF65 that someone had by-passed the safety switch. Very dangerous.
New switch costs about $10 and 2 ft of wire.
