Black Flag Forge
Greetings all,
Thanks in advance for your patience with this first time soon to be tractor owner.
I should be headed out this Wednesday to pickup a 202 work bull Model 200 Serial 5079 (No 30 in front of the number?)
I'm loading up my cart with parts I know already that I'll need but when picking out my missing air cleaner I didn't see an option for the connection pipe to the carb? This here:
Seller says they have a water pump leak of some sort but I'll look into that more once I'm in possession and check the seal vs replacement pump.
Guess I need to invest in my guide books now and figure out just how many hydraulic lines this thing has... Its the backhoe model with its own seat and straight down support legs and not pivoting outriggers which leads me to my next question.
The PTO or where it should be seems to have a steel cap or bottle shaped guard where the shaft should be, is it under there or did some of these models not include a PTO? The plate that holds the oil seal is there but just this odd projected cover sticking out.
I guess thats all for now till I can get her home and give it a good bath and detail any issues. The only thing I know right now is that she sounds great with zero knocking or clicking just the whistle of air entering directly into the carb.
Thanks much!
Wesley -Black Flag Forge Richmond Ky
Thanks much!
