Company Logo Shop Now
TractorLinks.com
MF12 bailer
Jbrock
08-12-2019 21:05:08
I recently bought an mf12 Bailee. At this point I ve soaked and replied all the chains and changed the gear lube. When I hooked it up and turned on the pto it ground and popped a shear bolt.
After considerable time thinking and consulting the manual I figure the pickup needs lowered but the manual seems very vague on how to do this. Can someone familiar with this shed some light on this?
Jbrock
08-14-2019 19:06:02
 Re: MF12 bailer in reply to Jbrock, 08-12-2019 21:05:08
It has the cup to keep the forks from getting bent. It runs
Off PTO though.
JerryCPP(WA)
08-14-2019 15:15:17
I don't know what to say about the pick up that has no lifting lever. All three of mine did have - it stuck out to the front beside the sheet metal hay guide, and had a one-stop bracket: lift it and push the lever into the slot, and the pick up stayed up for transport. Take the lever out of the slot and the pick up lowered. None of mine had a small wheel and tire - maybe that's the difference. Mine were all very early serial numbers. Mine had a large cupped plate that would hit the ground and lift the pick up so the tines wouldn't hit the dirt.
John G. Williams
08-13-2019 19:51:13
It may be that the timing of the packers needs to be reset. If the packers are in the bale chamber when to ram pushes to compact the hay it will cause a real mess. Instructions to set packers timing are on the pick up side of the main chamber behind the flywheel, assuming they haven't been painted over.
Jbrock
08-13-2019 17:03:39
A lever you can grab a hold of? Maybe I m missing something. Photos attached. How did you unstick the plungers?
Jbrock
08-13-2019 17:16:18
 Re: MF12 bailer in reply to Jbrock, 08-13-2019 17:03:39
For some reason they didnt attatch the first time.
JerryCPP(WA)
08-13-2019 11:39:34
I had a #9, #10, and #12. They all had the same setup to raise and lower the pick up, that being a lever pointing forward on the side of the baler by the pick up, right above the tire. Two of the three balers had stuck plungers; I had to free them up before they would turn. Two had Wisconsin TFD engines, and one was converted to PTO. One was wire tie and the other two twine tie. Basically they were all the same machine except for size. An owner's manual is a great help.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
