TO 30 Stuck in gear
Hooked180
A TO30 Massey Ferguson I am looking at is stuck in 4th gear. How do we get it to neutral? Also how do we
adjust the clutch? Any pictures would be great.
THANK YOU
After years of wear the shifter will manage into the wrong sift rail in the trans try removing the fill plug and use a bar and move the shift forks to the nuteral position. Should free up the shifter.
Owner Ferguson TEA-20.....
Bob....
(quoted from post at 10:43:22 07/26/19) After years of wear the shifter will manage into the wrong sift rail in the trans try removing the fill plug and use a bar and move the shift forks to the nuteral position. Should free up the shifter.
This is actually just as easy as sunbeam said. My MF202 got stuck so I could not move the shift lever either way. I removed the big fill plug and stuck a small pry bar in there and gently pried on the big gear just visible from the hole. I just moved that gear forward a little and the shifter lever was freed up.
You should put something like a piece of leather or something similar between the pry bar and the threads on the filler hole so you won't damage them.
