Marvel Schebler TSX Venturi Direction
SaveMy50
TSX 683 - just rebuilt by shop, but it was left in rain before it was installed and rust covered (I know, arggh). So I opened it up to carb clean it.
I originally tore down and I recall the venturi had a ring that kept it attached to main gasket. But when I opened this time the venturi was sitting loose and upside down (I think), ring away from gasket. And I cannot find information on line, including the Ferguson site that has a MS TSX Carb procedure. None of the videos I've seen show it either. Help appreciated.
Original Ferguson Service Manual....
Pic of Carb,used on TE-20 Fergusons with Continental Engine...
I have no idea if this is your Carb in question...
Marvel Schebler Carb....
Bob..Owner Fergusons and other Colored Tractors...
Thanks for the pictures.
So I fixed the upside down venturi, cleaned fuel bowl/line and air cleaner, and it started up ok but was idling high with minimal throttle control and no power.
I cleaned up governor linkage, and had to wind the throttle yoke out a couple turns to get idle down. Then I adjusted throttle needle in (minor stutter), then out (recovered ~ 1 turn out) and didn t change further, so left at 1 turn.
Power needle adjusted out turn after run on hill (no equipment to test).
Still a minor stutter, so checked ignition system wires, plugs, gaps, and found rotor was worn (>0.05 gap in cap) so replaced.
It appears to run ok now, stalls periodically, but cut a field yesterday.
