Tryingthis
New User
I have a 69 MF135, with front loader on it. With a diverted valve for auxiliary hydraulics.
I recently replaced the hydraulic pump, and when in the bottom i found the pot valve had blown the freezer plug out so i put the pot valve back together also. The rear lift will not work. i am getting hydraulic fluid up the tube to the diverted valve.
opened side cover and when i try to raise the lever to lift rear. tractor seems to be under load and hydraulic pump blows oil from the pressure valve.
i checked the lever action at the side panel and they seem to work good.
what could be the problem?
