Company Logo Shop Now
TractorLinks.com
44 throttle cable
1948 mm
07-11-2019 14:34:18
I have a massey Harris 44 early serial number and I need a throttle cable. Parts book only shows a metal rod not a cable. Looking for ideas. Thanks
Dieseltech
07-14-2019 12:22:19
 Re: 44 throttle cable in reply to 1948 mm, 07-11-2019 14:34:18
Very early MH used that heavy cable/housing on the governor spring. I had one on a parts tractor, not sure if it's still there, will have to look.
Mike in Mn.
07-12-2019 22:03:55
Some of the early 44's had a cable from the bottom of the steering column to the carb, I have only seen maybe two in my life, but they had a cable, it was heavier than a choke cable with a black coated housing.I don't know where to find one though, maybe convert it to linkage from a parts tractor.
kris Jensen
07-12-2019 09:14:45
There was a cable to the choke. Any universal one can be modified
The throtle to carburetor was metal rods, as in most tractors. controlled by the governor
1948 mm
07-17-2019 10:18:29
 Re: 44 throttle cable in reply to kris Jensen, 07-12-2019 09:14:45
rustred
07-11-2019 18:33:34
u thinking of the choke cable? throttle is all linkage.
1948 mm
07-17-2019 10:20:21
 Re: 44 throttle cable in reply to rustred, 07-11-2019 18:33:34
It had a cable
Centash
07-11-2019 18:02:22
No cable, just a metal rod from the throttle lever to the governor
ben
1948 mm
07-17-2019 10:21:19
 Re: 44 throttle cable in reply to Centash, 07-11-2019 18:02:22
1948 mm
07-17-2019 10:24:11
 Re: 44 throttle cable in reply to 1948 mm, 07-17-2019 10:21:19
Any pictures of a 44 with the rod linkage? Thanks
1948 mm
07-17-2019 10:28:53
 Re: 44 throttle cable in reply to 1948 mm, 07-17-2019 10:24:11
Mainly I need a picture of the pivot assy from the throttle linkage on the steering column (which moves left to right) and how it makes the throttle rod move back and forth
1948 mm
07-18-2019 14:54:33
 Re: 44 throttle cable in reply to 1948 mm, 07-17-2019 10:28:53
Nothing?
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
