linuxone66
New User
Hi the other issue I have with one of the 165's is:
The 3 point linkage is working fine but when I use the selector valve to switch to the FEL nothing happens.
I have taken the valve off and can blow through both ports, when I change position of valve slide it blocks off one or the other port however when I operate it, on the tractor, no oil comes out of the port to feed the FEL control valves.
Any insight to this one would be greatly appreciated.
Regards
Wayne
Regards
Wayne
