I recently bought a non running 203 with a locked up right rear wheel assembly
Got it running good
Took the planetary assembly apart on right rear wheel it was destroyed broken chipped gears bearings gone etc etc ...
After i unbolted the planetary assembly i see the axle shaft has 1 chipped tooth
My question is how do i remove the axle shaft i saw something in the manual about locking the brakes for that side ? Do i slide hammer the shaft out?
I already got used assemblies off a mf65 tractor that are in great shape and look the same
Do you think missing one spline will mess up my new planetarts ?
Got it running good
