Hi Guys, last year about this time I had a small knock in the engine, so put in a new set of rod bearings, nothing changed, still had that little knock.
Now its getting louder and notice engine is missing.
Had rocker cover off and could not pin point where the noise is coming from, checked and adjusted rockers, noise is still there.
When starting up no noise for about 5 seconds, then loud knocking, then when oil pressure gets up to 14lbs, the noise will lighten a little.
Just can figure out where this noise is coming from.
Tim
Tim
