Hi everyone,
I would like to adjust my throttle so that it comes on more gradual. My throttle goes from idle to higher RPM to quickly and would like to adjust it so that it comes on more gradual.
I have read all the manuals on linkage and governor adjustments and tried it and nothing changes. Under load going up a hill I don't sense the governor is doing anything.
I did change the governor and am aware of the pin needing to be at 8 o'clock. I have no recollection if I in fact did that step correctly nor any idea if its related nor what the operating results would be if that pin was not at 8 o'clock.
What adjustment would cause the throttle to react more gradual/slowly?
If it being caused by the 8 o'clock pin, it will have to run as it is for the foreseeable future. I am really behind on some projects.
Thanks in advance for the help!
Don
Don
