I changed my fuild and filter on the tranny because I would lose power every so often(like the filter was clogged)
Oil was milky so I flushed with diesel, by running it for five mins and cycled the 3 point a couple times.
After adding some UTF that was meeting or eceeding Permatran 3, the 3 point is now jumpy when lifting (same with the front loader). But beyond that there is an odd humming sound once the lift arms are all the way up (constant pumping position). The humming noise was not present before the change.
Any ideas?? Rings on the hydraulic piston?
PS the lift arms fall when the tracotr is off.
