275 massey hydraulic auxiliary valve adjustment
BOWTIEIH
Factory two spool valve, I have adjusted the dents on both levers but. with the engine off, the dents will hold levers locked both direction. Seem to function normally with engine off. But once engine is started you have to basically have to man handle the levers to either spool. As soon start to open valve you have to fight the levers, also you can hear the hydraulic system going under strain. It will operate equipment on cylinders but it is in a strain. Something has to be out of adjustment. I be think it is spool itself but I can find no reference in my books on adjusting this spool or online. Anyone dealt with this before.
